I hope this thread would be a bit of fun, and not intended to be too much of a slag-off. I don't think anyone is above making stupid mistakes from time to time, but in any office there always seems to be a whole lot of frustrating misconceptions that everyone just seems to go along with. Things that make you facepalm or die a little inside when you hear it. 'Rules of thumb' that make absolutely no sense. Conservatism in design taken to the extreme. Just general lack of understanding of basic concepts. I could go on...
For me, it is usually something along the lines of: "This is just the way we've always done it, so why change it?"
[li]General ignorance around the relationship between a structure's stiffness and its seismic response, often leading to a lot of tail-chasing and needless over-design. For example, specifying pot or spherical bridge bearings, which lock the bridge into the abutments and cause the structure to be very stiff in a lateral direction. The bearings and substructure then need to be designed for a very large shear force. Simply substituting these with elastomeric bearings would solve the problem in many cases (due to the base isolation effect), but there is this persistent idea floating around my office that the elastomeric bearings would have to be designed for the original shear force (calculated based on the superstructure being tied to the substructure) and therefore wouldn't work.[/li]
[li]Halving the length of a lap splice by adding hooks to both bars. Somehow this has been confused with the rule for development length, where the hook accounts for 50% of the development length. But it now gets routinely applied to lap splices, despite this not being allowed in our local code (or any code I am aware of).[/li]
[li]Needless caution around the use of stainless steel fasteners connected to non-stainless steel. I understand there is a risk of bimetallic corrosion when you connect a relatively large stainless steel item to some non-stainless fasteners. But when it is the other way around, I believe this is very safe to do. This seems to have developed into a rule of thumb whereby any dissimilar metals must not, under any circumstances, come into contact with one another. I've seen this leading to frivolous and expensive over-use of stainless steel and never seems to be questioned.[/li]
Would love to hear some of yours.
