Frustrated with If then else statement
jskintner
Bioengineer
I'm having a problem getting a If Then Else statement to work. All it needs to do is change the font color of a certain cell based on a comparison of the result of a formula in the cell to experience color change with the value of a scroll bar.
I know I'm close, but I just can't quite get it. I'm now getting a 424 run time error.
I'd appreciate any help offered.
Here's my current code. This was supposed to be a quick Macro, but is turning into a headache.
[Private Sub ScrVehiclePrice_Change()
Range("C4") = ScrVehiclePrice.Value
If MonthlyPayment.Value > ScrMaxPayment.Value Then
Range("C9").Font.Color = RGB(255, 0, 0)
Else
Range("C9").Font.Color = RGB(0, 0, 0)
End If
End Sub]
There is nothing wrong with your posted code, per se. I mocked this up and it worked as expected. The error you are getting indicates a problem with an object declaration/reference. I don't know what the rest of your worksheet and code looks like but my best guess is that MonthlyPayment is supposed to reference a worksheet control; a TextBox perhaps. If so, check to see that you renamed it after adding it to the sheet so that it is the same as in your code.
Mike
Thanks,
I found it. I appreciate the help.
