In cold winters roads around here freeze to depths of 10 feet. Only in some cases of frost-susceptible soils and available moisture does some frost heaving occur, usually not more than a few inches. In spring the roads thaw, and heaved areas return to essentially the original level.
Not the same as your situation but it does suggest not all freezing creates problems, depends on the soil and intended use.
