friction factor of steel rubbing against steel 2
wilg
Friends,
I need help. I'm trying to calcualte
the amount of force required to overcome
the hinge friction on a
36" wide x 84" high x 1-3/4" thick steel door
weighing 141 lbs. I have calculated
the torque created by air pressure differential
and have worked out the door closer effects.
What I really need is a friction factor
at the hinge.
This question is in relation to
ADA act of 1990
The Americans with Disabilities Act of 1990 section 4.13.11 reads as follows:
(b) interior hinged doors: 5 lbf (22.2N) 22.2 newtons .
Dry and unlubricated steel surfaces about 0.75 to 0.80. Good Luck.
Friction factor varies greatly depending on the condition of the steel surfaces. A dry lubricant such as teflon or graphite impregnated steel plates will help. Reinforced teflon can get down to as low as .08 to .1 sliding on a polished stainless plate.
Badly rusted and pitted surfaces rubing on each other can get up to .8 to 1
