Thank you Bbird for your answer
Yes, it’s true. For low force value (low pressure) friction coefficient is independent to pressure, but when the pressure is high, friction coefficient depend also to pressure. (I don’t know this correlation).
About material. I expect that correlation contain some material property and also some geometrical property of the surfaces (roughness). So I’d like to find some correlation like
Friction coefficient=function(load, material properties, geometrical properties)
Thank you again
By
Manini
