Friction and force analysis
  • Thread starter Thread starter g_zolee
  • Start date Start date
G
g_zolee
Guest
Hello. I
Pro/Mechanica can't help you with fluids.
For that you need a CFD as CF Design, EFD Lab or StarCD. These areexpensive tools, only worth to buy if you need it often.
Thanks.
But is there any possibility to simulate friction in ProE during the contact (it could be simplified)? I mean to generate a force depending on the material density and contact surface? For any idea I will be grateful.
Hi Zoli!
I'm not sure but guess you should use damper.
If you send me a PM we can discuss your problem in hungarian since UR from H if im right
