Hi All!
I wanna solve a simple cantilever-beam problem using a mode-based steady state dynamic analyses in Abaqus. I have a force at the end of the beam F=sin(freq). I want to make a verification with the theoretical model. We know the maximum displacement as Ymax=F*l^3/(3EI) using the theoretical calculations.
I have the results from Abaqus already for the selected frequencies of number 200 between 0-20000Hz. In the results we have displacements solved for each frequency. If we put the equation F=sin(freq) in the theoretical equation Ymax=F*l^3/(3EI) we dont have the correct result comparing with the theoretical results although the beam model is already verified by a static analyses. So I think we need to transfer the function using inverse fourier transformation to time domain and then will be the results correct?
I am a little bit confused so did someone know how to interpret and compare the result of a mode-based steady state dynamic analyses of a simple cantilever beam with the theoretical result?
Thanks in advance,
Eser
Thanks in advance,
Eser
