MikeSimpson
Marine/Ocean
- Jan 16, 2006
- 6
Can you please settle a professional dispute! A subcontractor is supplying a hydraulic powerpack driven by 3 x 3 phase 50Hz induction motors. We tested them at 50Hz and recorded current readings, my arguement is that this will reduce at a higher frequency. I base this on the inductive reactance increasing as the frequency increases. Rotor impedance will also increase, net result motor taking less current. Please advise if I am right or am I taking the client stand!
