Hi Everyone,
I have designed a freezer floor. My question is around the drawdown i.e. the dropping of the temperature of the concrete in the freezer room.
We are specifiying a typical drawdown procedure.
After 21 days of casting
1. Reduce temperature from ambient (approximately 22 degrees Celsius) to 2 degrees Celsius 5 degrees per day - 4 days.
2. Hold temperature at 2 degrees Celsius for 3 days.
3. 2 degrees Celsius to minus 25 degrees Celsius (5 degrees per day) 6 days
Due to timing requirements the client wants to start the draw down process earlier than 21 days. My question is that will the concrete still attain strength after it reaches 2 degrees celsius. Assuming no special heating measures to the concrete below what temperature will the concrete stop gaining strength (hydrating).
Comments appreciated.
