CWEngineer
- Jul 3, 2002
- 269
In the specs for a project it states that the Frame and cover for gratings shall be cast gray iron, ASTM A48/A 48M, Class 35B; cast ductile iron.
The contractor is trying to use Class 30.
Using ASTM A 48/A 48M - 03 (Standard Specifications for Gray Iron Casting), the minimum Tensile Strength for the Class 35B is 35 ksi and for the Class 30 is 30 ksi.
Basically from what I see the contractor is providing a Frame and Cover for Gratings of 5-ksi less than what is required.
This Frame and Cover for Gratings will be placed approximately 4 ft away from a Lake - where a vehicle is hopefully not expected to travel.
From your experience, would guys accept the Class 30 instead of the Class 35B? Or should I mandate the Class 35B be used?
