After a number of years working on bridge-type structures, I'm looking at a low-rise building for one of our newer projects. As such, I have a few questions regarding moment frame and shear wall design:
1) When working with a moment frame, is there a "better" method of determining lateral stiffness than modeling the frame with a unit force and correlating that to deflection? Is there standard equations to use (like with shear walls) that calculate the deflections quickly and easily?
2) I read in an outdated text that concrete moment frames must be poured monolithically. Obviously this is ideal but I can already hear the contractors complaining. Unless the rebar was insufficiently developed or the friction of the joint was too weak in shear, I don't see any reason for this. Any comments?
3) For moment frames with shallow footings, is it common to connect the footings with a strap rather than isolating each footing?
4) If a shear wall (or frame) is angled 45 degrees from the principal lateral load direction, how does it contribute to the stiffness of the system? (cos45? Neglected?)
Thanks!
Thanks!
