dbb
Materials
- Aug 27, 2003
- 3
When a seam-welded 5-gallon body is flanged (to accept top and bottom), the nugget on the flange fractures sometimes. The sample I have has one flange cracked and the other OK. The steel is .005 C, .13 Mn, .008 S, .043 Al, .058 Ti, .0039 N. Base metal ASTM grain is 9-10. Zinc coating weight is high at 1.2 oz/ft.sq. The properties of the base steel blank are uniform edge to edge, good DDS. The grain in the HAZ is blown to ASTM 2 to 4 and no failure. The grain in the fusion zone is ASTM 7 to 8 around the contact region with surface grain ASTM 4 to 5. In the failed nugget, the grain boundaries of surface grains have separated and there is mainly transgranular cracking through the nugget. No obvious collections of zinc in the joint. The fracture is brittle, not ductile.
Seems like some sort of embrittlement? What is the cause? Is this a form of CW embrittlement? Has increasing the welding current to accommodate the heavy zinc coating caused problems?
