I picked up a massive two cylinder Champion "Fire Protection System" air compressor. I am told it is typically used to pressurize a water tank at or near grade level, to give NFPA-required system pressures in multistory buildings without the use of a pump. In other words, rather than the head tank way up on the roof, like you used to see in the old days, you'd pressurize a large water tank that's down low, with air. Apparently the way these compressors were rated called for 40 psig discharge, and their capacity was measured in CFM of Free Air delivered in 30 minutes (duration of a fire?).
Does anyone have any history or experience on these types of compressors? I can't find anyone at the mfr. who can tell me if the compressor can be used for higher pressures. It certainly appears robust.
