twich
- Dec 17, 2002
- 10
I am the owner's representative, and an employee of the owner, on a court facility complex to be constructed adjacent and beside a historic 1896 Circuit Court building. I am a structural engineer and have some minor underpinning experience, but nothing like what is proposed. Also, the project is being designed by an architectural firm, who subed out the engineering.
My owner's contract with the Architect called out an additional fee for special foundation design for shoring and underpinning. No problem with that. Now the structural engineer is suggesting the underpinning design be included in the General's contract. Again, no problem, if my owner gets a deduct from the Architect.
The exterior walls of the old court building are a double wythe brick masonry bearing wall, bearing on limestone foundations, bearing on fine grained soils consisting of solf to hard clay and silt. The bottom of the stone foundation is 3'-6" below grade. The design calls for a basement in the new building butting against this exterior wall. There is little leaway in this design option, due to limited space in a downtown area. The excavation will be 15'-6" below and on a direct vertical plane from the stone foundation.
My question is: Should this task be "assigned" to the General, and if so, what pre-qualifications would you suggest I get before allowing any General to bid? Or should I insist the Architect hire a Structural Engineer that specializes in underpinning and shoring?
And does anyone have any tips on helpful sites I could access? Thanks in advance for you help.
TIH - twich
TIH - twich
