When the IBC changed the load combinations that have reduced dead load (0.9DL to 0.6DL +WL or EQ) they also changed the foundation stability factor proportionally from 1.5 to 1.0. This seems to assume that these particular load combinations always govern when it comes to foundation stability, which is not always the case. There are situations where gravity live loads are destabilizing to the foundation, therefore leading to a situation where other load combinations that don’t have a reduced DL govern the stability of the foundation. This creates a design discontinuity between the older and newer load combinations. For example, the LC with 1.0DL + 1.0LL would yield the same overturning moment and sliding forces for the new and old load combinations. If the LL is destabilizing to an extent which this LC governs, the new load combinations have virtually no safety factor, i.e., 1.0, whereas the old LCs would have a safety factor 1.5 requiring a larger foundation. This seems to have been an oversight.
Does anyone have any comments about this apparent discontinuity in design safety?
