Foundation Fieldbus
ppmsb
MY
Anyone got experience with foundation fieldbus system. We had experience some communication problem with the Rotork actuator.
ppm
I have worked on jobs using FF. There were "a lot" of communication issues in the early days, with various vendor's FF just "slightly" different than the next vendors. These issues are going down as FF matures - like anything else.
If you are having problems with FF communication, it may not be Rotork's fault (per se). It takes 2 to communicate. What is the system Rotork is communicating with? Perhaps, you can get reps from both companies to help with the problem.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
