civilman72
- Feb 13, 2007
- 408
I'm working on a design to install a foundation drain around an existing building. The site is flat and footers are 4' deep, so I have no place to discharge by gravity - it will have to feed back to a sump pump in the crawl space and I have some questions.
Is it important to have a separate sump pump for the foundation drain, or can I connect to the existing sump pump, which is used to discharge moisture in the crawl space floor (gravel surface)?
What is the best way to go from the outside footer into the crawl space? I was going to propose that the pipe go under the footer. The trench would only be 1' wide and should not affect the integrity of the foundation. If I try to go over the footer and through the foundation wall it will cause a negative grade in the pipe (since the pipe will be at the bottom of the footer). I could consider installing the drain at the top of the footer, which would not create a negative grade to get into the crawl space.
The foundation drain will be 4" perforated pipe, or could be a grouping of 4" perf pipe. The pipe that goes under (or over) the footer and to the sump pump in the crawl space will more than likely be solid pipe. What kind of transition design should I consider to ensure that the majority of the water in perf-pipe foundation drain (and surrounding select material) gets into solid discharge pipe?
I've read a lot of other posts concerning the type of materials to surround the perf pipe (i.e. concrete sand, clean rock, well-graded aggregate, etc.), and it seems that in all discussions there is material placed beneath the perf pipe. I recently spoke with a local geotech, and they are changing their typical foundation drain detail to not show material beneath the perf pipe - they want the pipe placed at the bottom of the trench and backfilled with select material. Their theory is that gravity pulls most of the water to the bottom of the trench, and that the select material below the pipe will not convey this water as quickly as the pipe will, so by placing the pipe at the bottom of the trench they argue they are moving the water in the trench more efficiently. Thoughts?
Your input and thoughts are appreciated.
