I am currently studying for an MSc and I am attempting to determine bearing capacity and settlement in a layered clay soil with weak clay overlying stiff clay.
I aim to design the foundation by fixing the length at 12m (assumption due to bridge deck = 12m) and determining width using Das equation. This is proving unsuccessful and I believe it is because Das equation is not appropriate for a weak clay overlying a stiff clay.
I also attempted using EC7 combination 1 but my values for B were not appropriate and I have been informed I cannot use this method for layered soils which is proving correct. I thought this would be appropriate because by balancing design resistance/acting forces = ODF the width could be calculated.
Does anyone have an appropriate method for calculating bearing capacity and settlement in soils with a weak clay overlying a stiff clay? Particularly a method which allows the engineer to determine a value for foundation width appropriate?
During my research I have only found method to solve situations with stiff clay over soft clay, sand over clay and stiff sand over weak sand.
Any help would be appreciated and apologies in advance if the details are unclear.
