I am working on a bridge pier cap formwork design. We typically don't get involved with formwork, however the bridge is over the RR and the RR is asking for almost everything to be stamped. The pier cap itself has the basic dimensions 41ft long, 9.5ft deep (center only) and 7.5ft wide. The Contractor is proposing to use 10ft EFCO panel forms (rated at 1200psf) and that seems fine to me since the pour rate wont be more than about 4-5ft per hour.
My question is determining the loads on the EFCO "ties" top and bottom. Through bolts are utilized along the bottom at 4ft centers and yokes (bent steel members bolted to the top of the form) are utilized at the top. Typically we use wire wall ties sized and spaced for our maximum wall pour pressure, however that approach is giving me very high loads in the through bolts and yokes.
How would I draw a wall pressure diagram for my 4-5ft per hour pour rate? Would it be fluid pressure with 5ft height? Once we get the forms full, what would the pressure be at the bottom of the forms. we have the forms continuously supported vertically.
I know the system works since I have seen it used many times, I am just struggling to show why. Thanks for your help.
