Formwork for Stemwall Foundation
mlzahn
Is there any reason why formwork for stemwalls, which have been backfilled against, needs to be removed?
I certainly understand the threat of termites on the wood formwork. But after the concrete walls have set, is the integrity of the formwork really a factor?
The integrity of the buried formwork may not be a factor, but buried wood can certainly be an attractive area for termites to gather, nest, and plan an attack on the structure.
Leave it and learn the hard way - but if you are in ALASKA - no problem!!
Or use steel/plastic form work
