formula: 1
  • Thread starter Thread starter -
  • Start date Start date
Guest
The r.c. spiral staircase which supports only from ground and the upper floor had a complex formula for twisting, torsion, and bending.Is there a simple version of design approached, if not I'm also interested in the process
of the design concepts.
I am pretty sure some friends will appropriately add lines here, but let there was a similar discussion a couple of months ago IN THIS FORUM and I remember Riz offered a spreadsheet even.
I thought you might want to go through previous threads as you wait for detailed responses.
Good luck
ed, it says that you are a visitor. Now to access the thread I have mentioned, do the following
1) click on keyword search tab
2) in the keyword field type: helical
3) Select Structural forum radio button
and begin the search.
good luck
