formula recognition
landrover77
GB
Gents
can someone give me a hint or two on the following please. I'm trying to work through some else"s calculations
i have a simple frame two vertical members, bridged at the top by a single Horizontal member.
Vertical height = h
Horizontal length = between vertical members = L
I1 = second moment of area for the vertical leg
I2 = second moment of area for the Horizontal
Load = P
the first formula, finds a ratio of second moment of areas x ratio of height to width
K = I2/I1 * h/L
Then K is used to find to dimensionless factors.
N1 = K + 2
N2 = 6K+1
the two N factors are then used in calcs to find moments.
eg; moment around ground level end of vertical legs. in vertical plane +PL/8N1
eg; moment around ground level end of vertical legs. in Horizontal plane -PH/2 * 3K+1/N2
I assume these factors just allow simplification of eqns, i'd like to see the derivation of these, its been a while since i've done any structural calcs, any help much appreciated.
thanks in advance
This looks like Kleinlogel. Your idea is correct. Simply expand them back into the formulae and you will see recognize the usual un-simplified versions of the formulae.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Thanks,
Reference is correct.
Steel designers manual appears to list his formulas.
