electricpete
1 – Can anyone tell me a formula to approximate the airgap flux Bg in an induction motor, given the stator voltage, winding configuration and geomtery.
2 – I copied directly from an EPRI text below.
I agree with equation 2.1 (derived from v=dPhi/dt 4.44=2*Pi/sqrt(2), sqrt(2) converts peak flux to rms voltage)).
I agree with equation 2.2 (this is simply N/2).
I agree with equation 2.3 (solves 2.1 for Phi).
I am confused by equation 2.4.
I would start with B = Phi/ (A/P) where Phi is flux per pole, A/P is area per pole
(A/P) = (Pi * ID * LEN) / P
B = Phi /(A/P) = Phi / {(Pi * ID * LEN) / P}
= Phi * P / ( Pi * ID * LEN)
But this does not agree with their 2.4. I vaguely remember also a factor of 3/2 for 3-phase machines associated with the overlap of three phases. I'm not sure if that belongs here but it still wouldn't make it work exactly. Any ideas how they came up with equation 2.4?
========= BEGIN QUOTE =================
The strength of the magnetic field is given by the following relationship:
E = 4.44 * f * N * Phi * Kd * Kp * 1E-8 (Equation 2.1)
Where:
E = internal voltage (applied volts, V, minus the IX voltage drop
of the stator winding)
f = frequency in Hertz
N = series turns per phase
Phi = lines of magnetic flux, flux per pole
Kd = winding distribution factor (value 0.9 to 1.0)
Kp = winding pitch factor (value 0.9 to 1.0)
The series conductors per phase, Z, is determined by Equation 2-2. Then, the total flux per pole in lines of flux, Phi, is determined,
equation 2-3. With the total flux per pole, the magnetic-flux density in lines per square inch can be determined for the air gap, Bg; the stator teeth, Bt; and the stator core, Bc.
Z = 2 * Q * T / (Paths * m) Equation 2-2
Phi = 10^5 * Volts / (2.22 * f* Z * Kd* Kp) Equation 2-3
Bg = Phi * P / ( 2 ID * LEN) Equation 2-4
Bt = Phi * P / (0.605*WT*Q*LEN) Equation 2-5
Bc = Phi / (1.9 * HI * LEN)
Where:
Z = series conductor per phase
Q = total number of slots
T = number of turns per coil
PATHS = number of parallel paths in the winding
m = number of phases
Volts = volts per phase
f = frequency
Phi = kilolines per pole
HI = core height in back of teeth
ID = bore diameter
WT = tooth width
N = 1/2 (Z) = series turns per phase
Kp= winding pitch factor
[LEN = Effective core length]
[ P = Number of Poles]
Constants, 0.605 and 1.9, include an insulation between lamination factor of 0.95.
Note: All dimensions are in inches.
============= END QUOTE ============
Where:
Where:
f = frequency
ID = bore diameter
WT = tooth width
