I imported an AutoCAD format into ProEngineer. In the formate where the material is specified, it original read "MAT'L : X" where "X" would be modified by the user. When I imported the format into ProE, I changed this to the following "MAT'L : &material" so that the material would be directly retrieved from the model. However, this isn't working. When I bring the model and format together, the &material parameter isn't being changed. Am I doing something wrong?
When I create a table within the format and put "MAT'L : &material" inside the cell, it works perfectly. Do I have to construct my formats as a series of tables in order to get the parameters to correctly update?
Thanks in advance for your help.
