Formaldehyde process: steam production 4
roker
Chemical
IL
In Formaldehyde plants (with metal oxide catalyst) steam is produced in a heat exchanger by condensing vapors of a thermal fluid which is circulated in the Formaldehyde reactor jacket.
Can someone clarify why the water is not circulated directly in reactor jacket?
regards,
roker
If water were used directly it would have to kept under pressure to avoid having it boil in the reactor. I forget the actual operating temperature of the reactor, but it is well above 100 C. Formaldehyde reactors are large and to make this as a pressure vessel would be very expensive. It is more economic to use a heat transfer fluid and then produce steam in a smaller unit.
There may also be statutory factors. Here in South Africa a boiler is legally defined as "a device generating vapours from a source other than steam". This would make the reactor a boiler, with all the rules and regulations that go with it. It is easier to satisfy the regulations (at least here in SA) in a separate vessel.
It comes down to the selective properties of the catalyst. Normal operating range for the mixed oxide catalyst is 257 to 308 C. Diphenyl Oxide/Biphenyl Blend with an atmospheric boiling point of 257 C is used as the thermal fluid.
HCHO plants use shell and tube reactors with anywhere from 10,000 to 18,000 tubes. Typically these are 5.0 ft x 1.0 inch OD, 13ga and set at a pitch of about 1.25 inch. Max operating pressure using the oil is about 2.6 bar, with water you would require in excess of 85 bar!
