MacGyverS2000
Is the form of tachometer data fairly standardized in most modern cars these days (or even in earlier cars)? Is it generally a PWM duty cycle that determines rpms, or maybe a simple pulse per second count, etc.?
I would like to make measurements of rpm, but the unit should be as generic as possible (i.e., I can use it on as many vehicles as possible). If more than one common method existed, I could either build more than one unit or attempt to combine all methods into a single package with a simple, switchable universal interface.
Thanks!
Thanks!
