form Load (probably just a dumb mistake)
fdg
Computer
In a program I am writing, I want a form to appear, when you click a button, that shows a different picture depending on what button you push. I currently have the code written:
(form 1)
Private Sub Form_Load()
Open "c:\mun.txt" For Output As #2
Write #2, "0"
Close #2
End Sub
(command button 1, form 1)
Private Sub Command1_Click()
Write #2, "1"
Close #2
Used.Visible = False
Used2.Visible = True
End Sub
(command button 2, form 1)
Write #2, "2"
Close #2
End Sub
(form 2)
Open "c:\mun.txt" For Input As #2
Input #2, string
Text1.Text = string
If Text1.Text = "1" Then Picture1.Visible = True
If Text1.Text = "2" Then Picture2.Visible = True
If Text1.Text = "3" Then Picture3.Visible = True
If Text1.Text = "4" Then Picture4.Visible = True
If Text1.Text = "5" Then Picture5.Visible = True
If Text1.Text = "6" Then Picture6.Visible = True
If Text1.Text = "7" Then Picture7.Visible = True
If Text1.Text = "8" Then Picture8.Visible = True
If Text1.Text = "9" Then Picture9.Visible = True
If Text1.Text = "10" Then Picture10.Visible = True
If Text1.Text = "11" Then Picture10.Visible = True
Close #2
End Sub
When I do a runtime debug, no matter what button I push on form1, the same picture cames up on form2. Can anyone help me? Can I use the Load sub for this function?
I've only given your code a quick glance, but if you are trying to change the picture after form 2 loads it will not work. The picture changing logic only appears in the form load event which will only happen once (unless you unload and reload the form). If this is the case you may want to move the picture changing code to its own subroutine such as
{somewhere in form 2 code}
public sub ChangePic(PictureNumber as integer)
select case PictureNumber
<add your code here for different pictures>
end sub
Now you can add code to form 1's command buttons such as...
[button for picture 1]
call form2.ChangePic 1
I hope this helps you, it should even eliminate the need for writing out a value to a text file just to pass a variable around.
