Forged Alloy 825 Valves
lcarter157
My service is Hydrogen, Wet & Sour. The client's pipe specifications call for B564 (Forged) N08825 Valves, I have sizes up to 10" and 1500# class. Vendors tell me that they cannot supply to B564, they quote A494 (Cast) instead.
ASME B16.34 does not give a pressure rating for A494 N08825 material. In fact N08825 is not listed as a cast material,the only materials per A494 are Hastelloy B & C.
Are larger valves (6") available in N08825 per B564? Surely we are not the only ones in this service.
Thank you.
I checked the chemical composition and machanical properties of B564 N08825 and A494 N08826. Please note that it is not A494 N08825 but A494 N08826(CU5MCuC). There is a different for their tensile strength(586MP/520MP). It is recommended that in the hydrogen industry in view of the hydrogen corrosion forged valve is more reliable.
Thanks Larry,
yes I know that A494 N08826 is not a good substitute.
What valve type are you looking for?
Luxeal
Luxeal,
I need 2", 3", 4" & 6" 1500# RF Globe Valve, ASTM B 564 N08825 per ASME B16.34. The client piping specification for this service calls for valves as large as 24" in this material, so far, I have not been able to find a manufacturer who can supply a valve larger than 4" in B564 N08825 (Forged) - the only offerings have been for castings per ASTM A 494 in Hastelloy. Cast N08825 is not listed in B16.34.
Also, the only offerings that I have had for the smaller valves have been for bodies machined out of bar stock. Acceptable, but not forged.
Thank you,
As far as I know, globe valve suppliers are more used to deal with large projects and standard materials. Have you considered MSBVs?
Luxeal
Forged valve bodies will require a construction of a forging die. The manufacturers are balking at your request because even small dies are quite expensive. We were looking at a die for a 3" plug valve and the die cost was nearly $40k. I can't imagine what a die would cost for a 24" 1500# globe valve. Additionally even if you were willing to pay the cost to develop the dies, finding a forge that could handle such an endeavor, and be willing to make a small production run in an exotic alloy would be challenging. If the manufacturer does find a forge you can bet they are going to charge big bucks to accomodate the order.
Good luck,
VRF
KOSO Kent Introl make a range of high pressure Forged Valves (Control & Choke Valves) might be worth looking at.
