JamesBarlow
I looking to find out if there is a way to force SW to dimension, specifically a radius, with a diameter.
I found that bolt circles are created using radiused sections of center line so when I go to dimension it I only get a radius.
I also have a case of a sprocket with a shaft hole and key slot. Because of the key slot I get a radius instead of a diameter.
An way to make it do this.
