YoungGunner
The SDPWS does explicitly permit the aspect ratio for force transfer walls to consider the aspect ratio for doors, though there aren't many great methods of calculating the strap force in those segments. This also opens up a can of worms of whether for taller walls, we can effectively still only use the aspect ratio for the door? See images for examples, assume the tall versions have no floor system breaking up that wall height. My specific questions:
1. What method do you use to calculate strap force for a garage door scenario?
2. Are there any scenarios below you would flag as "not acceptable" for force transfer?
3. Where windows stack, what do you do about aspect ratio?
4. What do you do about designing the hold-downs for the piers?
