1.Need the brg no and make if you would like a quantified value in answer and suggested design for the puller unit..
OR
2.If the manufacturer and/or local supplier is easily accessible to you right away, get the dets from the horse's mouth straightaway.
a) Heat the brg with local open flame and/or induction coil heaters. Will ease the fit atleast to the extent the puller can pull off with ease - expect ~1.0 to 1.25 times the force
initially utilised to final-seat the brg, had it been a shrink fit on the tolerances.
b)A 3-Jaw std design puller w/ a hyraulic pusher cyliner arrgt capable of 3.0T -5.0T hydr load should work.
c) Personally have also used a simple plate puller sized to seat 'behind'the brg on its seated posn and use hydr force as above toease it out.
d) NO HAMMERING pls- if you do, forget any reuse of the brg.
