1SEngineer
- Aug 27, 2007
- 37
We are designing a metal frame building which will abut an existing metal building.
In order to maximize floor area we'd like to place the the steel columns of the new building directly next to the slab edge of the existing building.
The existing metal building foundation is a thickened edge 12" deep x 18" wide.
We have a few options, but we feel the cheapest would be to add a new rectangular shaped footing next to the existing thickened edge. The new footing would be 4' wide x 6' long. 1.5' of the width would be from the existing footing.
We'd calculate the bearing pressures and use these numbers to design epoxy embedded steel reinf. to be connected to the bottom of the existing footing to transfer tensile (and shear) forces. We be enlarging the spread footing. This approach is shooting from the hip a bit but we are curious to know if anyone has done something similar (and had no problems : - )) ?
The other options would be to offset the column far enough from the exiting thickened edge to create a completely isolated footing. This reduces the amount of interior space and creates other space problems.
Another option is to use helical or pin piles to pick up the new loads. Of course this adds more cost to the project.
Cutting into the existing buidling is not an option.
Thanks in advance for any comments!
