bspooner,
Thanks for your input. I would like to know what exactly to look for in the detaile analysis of glycol. We have visually checked the appearance of the glycol and it is dark brownish in colour, besides the ph is found to be above 7. The temperature at which we run the reboiler is 200 deg C.Our circulation rate is 2500 kg/hr, and this is as per the vendor's operating procedure. Do you think we can still operate at lower rates? How do u think the slow rate of circulation will help?
Further from a purely theoretical standpoint and for a better understanding of the problem could u enlighten me as to the root causes of foaming? ie all possible sources/ conditions/parameters/contaminations etc.
What is a typical glycol analysis? what should be the specifications and what are the limits and deviations?
Thanks and regards
