gte447f
- Dec 1, 2008
- 806
I have a situation where foam jacking (pumping expansive polyurethane foam under the slab to lift the slab) is being proposed to lift a slab on grade that has settled behind a retaining wall. Should I be concerned about possible lateral pressure on on the retaining wall from the foam? The wet weight of the foam? The injection pressure? The expansive pressure? My gut tells me that the pressure is minimal, but I have not been able to find any references addressing the issue.
A few additional details... The retaining wall is an 8" thick cip concrete wall 10.5 feet high. The slab is 10'x10'x12"thick bearing on backfill on the retained side of the wall. The edge of the slab opposite from the retaining wall has settled about 6-8 inches. The edge of the slab on the retaining wall side has not settled at all because it actually bears on the top of the retaining wall. One corner of the slab opposite from the retaining wall has a post on it that supports the corner of one floor and a roof above (about 100sf of each). There are no other loads on the slab except foot traffic.
