FMC pneumatic valve actuator help
dino50
GB
Hi all, im new on here and looking for a bit of help/advice. Im trying to open up an actuator to check for damage but im not sure how to go about this. The actuator is fail closed and the bottom cover of the spring assembly has 4 bolts in it fitted with large thick washers. Ive removed these but the plate doesnt move. It looks as though there may be a ring/groove set up holding it in place. Can anyone offer any advice.
cheers Dave
My advice is to be sure you understand how to disassemble anything when it could have a compressed spring. Stop work, and get a maintenance manual from the manufacturer.
Valvit
