CMalenofski
- Sep 14, 2018
- 4
After reading the 2015/2016 DS 1-28 I am confused about the application of the FM Global loads. They run through calculations comparing results to ASCE 7-10 with both ASD and LRFD loads. What I can't tell is if I am to be using these loads with ASD or LRFD capacity equations for my structural members. They are calling it a design pressure but a few times in section 3.10 they refer to the FM Global loads being the ultimate pressures.
The standard doesn't seem to indicate how the material capacity is to be calculated. Should it go into the LRFD equations with 1.0W or ASD with 0.6W? They seem to say not to use the 0.6 factor but you get a much greater capacity from phi*Mn than you will from Mn/Omega if you just use 1.0W. Is there a definitive answer somewhere?
