jmk407
- May 30, 2012
- 5
This should be a relatively easy question, but it's been racking my brain for a little - more of a though experiment that developed at a meeting where a coworker asked about connecting a separate pump to the pipe at a vertical storage tank outlet. One thing I needed to look at was the backpressure due to the static head in the tank, and my brain decided to frustrate me.
The storage tank is about 30' high. The tank outlet is at the bottom, which is piped to a transfer pump. This pipe also has a solenoid valve upstream of the pump, for the sake of this question assume it is normally open, and the pump is off. The initial pressure at the pump inlet is a function of the height of fluid in the storage tank. If only the valve is closed, and the pump is not running, will the pressure downstream of the valve be what it previously was, even though it is hydraulically separated from the tank?
thanks!
thanks!
