Ultganon
Student
- Jun 19, 2021
- 7
If I have a pump that is discharging say 500GPM into a 10" pipe and somewhere down the line the pipe splits in two and the other is a 6" and they are both open to atmosphere at the ends how does this affect the fluid flow? I know Q=AV plays a role here but does the GPM split evenly between the 2 different diameter pipes? Or does velocity remain constant throughout the whole system (which I don't think this is valid since a lower diameter should increase velocity due to A1V1 = A2V2). Most questions always give you almost all velocities and all flows and you have to solve for 1 variable but what if you dont know the velocities in discharge pipes or their flow rates?
