element94
- Dec 2, 2004
- 30
I need some help with COSMOS FLoWorks. I'm doing external flow analysis with questionable results. FLoWorks is showing a drag force of 2 lbs on an object I know has around 70 lbs. When I show flow trajectories they flow thru the body and not around. It's like the body does not exist. It's not the component control because all bodies are enabled. Help please. Thanks.
