bmsg
- Oct 27, 2003
- 45
I have an application where I have to totalise the flow value of coke oven gas (in a steel plant)in a PLC based automation system. For this, I have a flow transmitter in the field which gives a 4-20mA DC output corresponding to the flow range.
Can I use this 4-20mA signal directly in the PLC(through analog input card)for totalisation of this flow? Or, should I convert this 4-20mA DC signal into a pulse signal through an external pulse convertor and then feed the pulse signal to a pulse card of the PLC for totalisation?
Which philosophy will result in better totalisation accuracy?
Or is it better to use an instrument generating a direct pulse signal corresponding to the flow and then feed the pulse signal to a pulse card of the PLC for totalisation?
BMSG
BMSG
