Hi, I'm designing a cell to measure the electrical resistivity of a dielectric liquid during flow. I performed simulations and found that if i use a design with two electrode rings within an insulating pipe, it would require relatively large dimensions and thus a large volume if i want the cell constant small enough to measure a high resistivity. So, i'm trying to design a cell with two perforated plates opposite each other to do the measurement as i would need less volume of liquid (i'm testing liquid R134a which is bad for the environment so can't use a lot of it) and i was wondering if you guys have any ideas about how to do this. I would like to minimise turbulence and have less holes for liquid to pass through so i can lower my cell constant by having a larger surface area of the plate touching the liquid. I'm trying to get a cell constant value of 0.1 m^-1 and i've calculated to find that i'd need a circular plate with a diameter of 15cm assuming no holes and a 2mm distance separating the two plates. Do i use many small holes or a few large ones? How can i find out the optimum hole to turbulence/cell-constant ratio? How would i attach these plates into position within a plastic pipe? Should i make the plate thick so that there is a larger area in contact with the liquid (i.e. the inside walls inside the hole), would this area factor into the cell constant equation, if so how? Is there a way i can create like a sluice gate mechanism within the pipe so that i can like store the liquid before releasing it to make the measurements with the plates to minimise required volume and ensure 134a is pressurised to liquid state during measurement? Thanks in advance.
