Patrick:
Am I correct in interpreting that you have plug valves in your lines as main block valves through which you plan to pig? Unless I miss my guess and you are using a "special" type of pig in your process lines, you may may not be able to carry out your pigging operation with conventional plug valves in your lines. Another way I could be wrong is if you are using over-sized plug valves in your main lines as block valves (which is an expensive way to go). I hope that I am wrong and that you simply are referring only to the plug valves used to introduce the pressure medium behind the pig (air?).
What I'm referring to is that every plug valve that I've bought and operated had a conventional reduced port. If you can visualize the way and manner that a plug valve is fabricated and the way it works, you will agree that unless you install an over-sized model in the line (complete with concentric expanders) the pig will stop dead in its tracks the instant it hits the under-sized, conventional "bore" of the plug valve. In fact, depending on the type of pig and the way you run the pigging operation, you may have problems with the pig jamming itself at the concentric expander junctions due to the pig getting mis-aligned with the concentric "bore" of the valve. This used to be a problem when gates (with inherent reduced bore) were the standard in pipelines being pigged. Today, with "full-bore" ball valves being the valve of choice in most pipelines, the problem has gone away. One way to resolve the mis-alignment problem is to elongate the pig -i.e., make the pig long enough so that it remains fairly stiff and straight as it negotiates its way through the over-sized valve and both expander/reducers. However, when you do this, you make it harder for the pig to go through ells and off-sets within the piping system. I hope I'm way off target with this comment.
My point here is not to make or raise new problems for you but to alert you should you not have taken the above into consideration - if, in fact you have plug valves in your main lines. I'm sure other engineers experienced in pigging operations will want to comment. My ears pricked up the moment you mentioned PIGGING - which you failed to mention before in the thread.
I hope this helps to straighten things out rather than confuse them.
Art Montemayor
Spring, TX
