_______
I have a main pipe that's divided into 2 branches. All 3 pipes have the same elevation. I have a manometer on each one of the smaller pipes, so I know the pressure there, plus I know the velocity of the fluid on the smaller pipes and on the main pipe. But I'd like to know the pressure on the main pipe just before the fluid splits in two.
I was comparing this system to an electrical circuit with 2 parallel resistors, where the voltage is kept constant throughout the system and the current is divided into the 2 resistors. I don't know if this system could be compared to an electrical circuit because the fluids do not rejoin, they're discharged on a vessel. But anyways, I considered the total energy of the fluid represented by the Bernoulli equation as the voltage on the electrical circuit and I did the following (ignoring friction losses):
(P3/density)+((V3^2)/2g)=(P2/density)+((V2^2)/2g)
3 for the main pipe
2 for the smaller pipe
The only thing I dont know in the equation is P3 so according to what I'm thinking I could calculate it. Am I right? Is it possible to use Hardy-Cross here, since I know the flow on each pipe to figure out the pressure on the main pipe just before the fluid splits in 2?
3 for the main pipe
