PAN
- Apr 25, 2001
- 549
The catalog indicate allowable momentary flow rate of the flowmeter. If the actual flow rate is higher than this value, what will be the side effects? Is this only the fault reading of flow rate?
This flowmeter can withstand 10 kg/cm2. The pump shut off pressure is less than this pressure.
Please advise me about the references for further study in this subject.
