student00
Industrial
- May 6, 2008
- 1
Working on a problem and looking for feedback. I have a DP element on a steam application, there is concern the measurement is not accurate. The install has the impulse lines at a 45deg to a condy pots, then a wet legs to the transmitter, fairly standard. Thermal imaging shows the High side pot to be 105C down to 60C and the low side steady at 30C.
Any thoughts as to why the differential in temp? Is this the cause for the error?
