gasoperations
- Nov 23, 2008
- 59
Has Anyone experience in measurement of Water / oily water from drain of the Crude Oil storage tanks? Local mechanical readout is enough. No need for advanced measurement system with signal routed to remote station. The drain from the tank is gravity flow to the treatment pit.
The challenges as I see are:
- No power or utility available in tank farm
- Low pressure available on upstream side ( max. liquid height is 12 meters. Min height is 3 meters )
- Water is expected to be contaminated with crude oil ( <20 ppm ). But occasionally oil could also pass through the drain system for short duration. Sp. gr of oil is 0.8 with pour point of 10deg Cen.
Is there any make model available with total mechanical system / Portable power pack for hazardous zone.
Any help will be greatly appriciated
