Jhon Stenvall
- Mar 8, 2020
- 3
Hi, I'm a junior engineer currently working on a water park project. Right now I'm checking the hydraulic design of a small water slide. Basically the system have two tanks: one being the pool and the other being the balance tank. There are two 2HP centrifugal pumps wich have their suction pipe connected to the balance tank and they discharge to the slides, then the water flows down to the pool and back to the balance tank through three 6 inch PVC pipes. As you can see it's a cyclical system. By the way both pumps discharge a total of 100 m3/h (50m3/h each). The two tanks have the same water level when being at static conditions but the pool depht is 1.3 m (dimensions 10mx5mx1.3m)and the balance tank depth is 1.55 m (dimensions 3mx4mx1.55m). My question is the following: As you know there have to be a difference in levels to produce a dynamic flow between the pool and the balance tank. I calculated this head and the result was approximately 6 cm. Now, considering that both tanks have the same initial level, after the pumps are turned on and the cyclic process starts what do you think will happen:
(1) Will the pool level increase 6 cm and the balance tank will keep its initial static level?
(2) Will the balance tank decrease 6 cm and the pool will keep its initial static level?
(3) Will the pool level increse by 3cm and the balance level decrease by 3 cm making a total difference of 6 cm?
Note that there will be water in the pipe system and the slides that will make both the tank and the pool decrease its level but for this question it's not considered. Please take a look at the diagram attached.
Thanks in advance.
JOHN
Thanks in advance.
JOHN
