I am currently working to strengthen an existing floor slab where new heavy equipment will be installed on the floor above.
I have attached the plan view of the area below for reference. The 3no. beams shown are actually not supporting the slab and they are there to only support the high voltage cables(I also attached the photo of the area).
Due to heavy equipment that is going to be installed above, this area needs to be strengthened. My initial thought was to just provide some trimmer beams in order to reduce the slab span from 3.310m to around 1.000m where the slab would be sufficient. However, the problem is the buildability part in this area. Due to the presence of high voltage cables underneath, there is no way of building a scaffold to install the trimmer beams. I am really struggling to come up with a solution that would strengthen the floor without actually working above the HV cables.
Is there any ideas/suggestions for potential solution for this issue?
Please let me know if you require any further details and I can provide them here.
