dduray
- Feb 5, 2006
- 2
I am investigating the cause of some uneven concrete floor slabs. The building had been used for an ice skating rink. The existing floor slab consists of a 3 1/2" slab on grade, in good condition, around what was the ice rink. The new owner of the building hired a contractor to "fill in" the area which was the ice rink with a 3 1/2" concrete slab. The slab was poured in sections approx. 85'x43' with zip strips placed creating slabs averaging 20'x 20'. The new slab has cracks at about every 10' and has apparently curled adjacent to existing slab in some areas as much as 3/4". The new slab was installed with heating tube. The new slab was placed on 3" of crush aggregate with fines which was on top of the existing 1" foam insulation. The issue is the cracking and more importantly the apparent curling which has created a tripping hazard. The Contractor is claiming that the owner turned on the heating system to soon and caused the cracking and excessive curling. The owner apparently turned on the heat 30 days after the concrete was poured. I think that some of the curling was not curling but poor workmanship. Does anybody have any experience with this or know of any references pertaining to curing slabs with heating tubes?
