BridgeSmith
- May 22, 2009
- 5,098
This should be a simple question, but I'm not very familiar with the building code. The loft is just under 200 square feet, if that matters.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Not sure what you are asking here. The IBC and NDS do have span tables for DF 2x joists of various spans, spacing and loads.Is the 125psf the ultimate load? Using that load, what strength would I use for Douglas Fir 2x joists?
You nailed it - it's for Christmas decorations (mostly trees), so I will probably stick with the 100psf I originally assumed when I laid out the framing plan, and post it, if I can.Conversely, as I said above, you could design for what you calculate/determine is the most likely maximum weight on the floor and then post the live load limits on the door and in the room.
We've done similar things with those pesky not-really-a-storage-room spaces as 125 psf is fairly robust if the church is storing boxes of Christmas decorations.
I was only planning on using 12" and 16" oc. The sheathing layout (and the framing plan, for that matter) are already a nightmare The 3 walls are all at odd angles. Relative to the opening across the front, the 2 ends are at 7o degrees and change, and the back wall is skewed 12 degrees and change.I wouldn't alter the spacing as that tends to make the floor sheathing layout a nightmare. 12" o.c. or 16" o.c. or 19.2" o.c. or 24" o.c. allow for the 4' x 8' sheets to work out with minimal cutting and waste.
JAE said:From a quick hand calculation I'm getting a 2.3" live load deflection vs. an L/360 limit of 0.63".
